免費論壇 繁體 | 簡體
Board logo
标题: 无界仿X3论坛积分进度条测试可用 [打印本页]
作者: Yenifer    时间: 2023-6-1 12:05     标题: 无界仿X3论坛积分进度条测试可用
编辑viewthread_node.htm模板
找到
  1. <p>{eval showstars($post['stars']);}</p>
复制
下面添加
  1.     <!--积分进度条-->
  2.     {eval $q2 = $db->query("SELECT * FROM cdb_usergroups WHERE type='member' ORDER BY creditshigher");}
  3.     {eval $jfjdinfo=Array();}
  4.     {eval $i=0;}
  5.     {eval while ($asdfgh=$db->fetch_array($q2)) $jfjdinfo[$i++] = $asdfgh;}
  6.     {eval $jifen=$post[credits];}
  7.     {eval $jflevel=0;}
  8.     {eval $jfnum=0;}
  9.     <!--{loop $jfjdinfo $zzz}-->
  10.     <!--{if ($jifen>=$zzz[creditslower])}-->
  11.     {eval $jflevel=$jflevel+1;}
  12.     <!--{/if}-->
  13.     {eval $jfnum=$jfnum+1;}
  14.     <!--{/loop}-->
  15.     {eval $jflevel4=$jflevel+1;}
  16.     <!--{if ($jflevel4<$jfnum)}-->
  17.     {eval $jflevel2=$jflevel+1;}
  18.     {eval $jfper=floor((($jifen-$jfjdinfo[$jflevel][creditshigher])/($jfjdinfo[$jflevel][creditslower]-$jfjdinfo[$jflevel][creditshigher]))*100);}
  19.     {eval $wanfen=$post['credits'];}
  20.     <!--{if ($wanfen>9999)}-->{eval $wanfen1=floor($wanfen/10000);}{eval $wanfen2="万";}<!--{else}-->{eval $wanfen1=$wanfen;}{eval $wanfen2="";}<!--{/if}-->
  21.     <style>
  22.     .pbg2 {display: block;height: 10px;width: 130px;margin: 0 auto;background: url(http://www.discuz.net/static/image/common/ico_jdt.png) 0 -10px repeat-x; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px;}
  23.     .pbr2 {display: block;height: 10px;background: url(http://www.discuz.net/static/image/common/ico_jdt.png) 0 0 repeat-x;-webkit-border-radius: 5px;-moz-border-radius: 5px;border-radius: 5px;}
  24.     .postauthor{overflow:visible!important;}
  25.     .jfts{bottom:22px;left:15px;position:absolute;z-index:999;overflow:visible!important;}
  26.     .jfts_horn{left: 10px;bottom: -12px;background: url(http://www.discuz.net/static/image/common/tip_bottom.png);position: absolute;width: 11px;height: 6px;overflow: hidden;}
  27.     .jfts_back{margin-bottom: -26px;padding: 18px;width: 260px;border: 1px solid #B1B1B1;background: #FEFEE9;}
  28.     .jfts_word{bottom: 3px;left: 12px;position:relative;}
  29.     .jfjd{position:absolute;left:78px;top:-1px;color:#000000;}
  30.     .tip{border:0 none;border-radius:5px 5px 5px 5px;padding:8px;overflow:visible!important;}
  31.     .tip_c{line-height:16px;overflow:visible!important;}
  32.     #jindutiao{position:relative;margin:5px 0 5px 0;}
  33.     .hide .jfts{display:none;}
  34.     .show .jfts{display:block;}
  35.     </style>
  36.
  37.     <div id='jindutiao' class='hide' onmouseover='this.className="show"' onmouseout='this.className="hide"'>
  38.     <p>
  39.     <span class="pbg2"><span class="pbr2" style="width:{echo $jfper}px;"></span></span>
  40.     </p>
  41.     <div class='jfts'>
  42.     <div class='jfts_back'></div>
  43.     <div class='jfts_horn'></div>
  44.     <div class='jfts_word'>{$post[authortitle]},积分 $wanfen1$wanfen2,距离下一级还需 {echo ($jfjdinfo[$jflevel][creditslower]-$jifen)} 积分</div>
  45.     </div>
  46.     </div>
  47.     <dl class="pil cl" style="margin: 5px 10px 5px 20px;">
  48.     <dt>积分</dt><dd><a class="xi2" href="memcp.php?action=credits" target="_blank">$wanfen1$wanfen2</a></dd>
  49.     </dl>
  50.     <!--{/if}-->
  51.     <!--积分进度条end-->
复制
欢迎光临 SclubFans (http://sclubfans.imotor.com/) Powered by Discuz! 7.2
