查看: 2049|回复: 0
编辑viewthread_node.htm模板
找到- <p>{eval showstars($post['stars']);}</p>
复制 下面添加- <!--积分进度条-->
- {eval $q2 = $db->query("SELECT * FROM cdb_usergroups WHERE type='member' ORDER BY creditshigher");}
- {eval $jfjdinfo=Array();}
- {eval $i=0;}
- {eval while ($asdfgh=$db->fetch_array($q2)) $jfjdinfo[$i++] = $asdfgh;}
- {eval $jifen=$post[credits];}
- {eval $jflevel=0;}
- {eval $jfnum=0;}
- <!--{loop $jfjdinfo $zzz}-->
- <!--{if ($jifen>=$zzz[creditslower])}-->
- {eval $jflevel=$jflevel+1;}
- <!--{/if}-->
- {eval $jfnum=$jfnum+1;}
- <!--{/loop}-->
- {eval $jflevel4=$jflevel+1;}
- <!--{if ($jflevel4<$jfnum)}-->
- {eval $jflevel2=$jflevel+1;}
- {eval $jfper=floor((($jifen-$jfjdinfo[$jflevel][creditshigher])/($jfjdinfo[$jflevel][creditslower]-$jfjdinfo[$jflevel][creditshigher]))*100);}
- {eval $wanfen=$post['credits'];}
- <!--{if ($wanfen>9999)}-->{eval $wanfen1=floor($wanfen/10000);}{eval $wanfen2="万";}<!--{else}-->{eval $wanfen1=$wanfen;}{eval $wanfen2="";}<!--{/if}-->
- <style>
- .pbg2 {display: block;height: 10px;width: 130px;margin: 0 auto;background: url(http://www.discuz.net/static/image/common/ico_jdt.png) 0 -10px repeat-x; -webkit-border-radius: 5px; -moz-border-radius: 5px; border-radius: 5px;}
- .pbr2 {display: block;height: 10px;background: url(http://www.discuz.net/static/image/common/ico_jdt.png) 0 0 repeat-x;-webkit-border-radius: 5px;-moz-border-radius: 5px;border-radius: 5px;}
- .postauthor{overflow:visible!important;}
- .jfts{bottom:22px;left:15px;position:absolute;z-index:999;overflow:visible!important;}
- .jfts_horn{left: 10px;bottom: -12px;background: url(http://www.discuz.net/static/image/common/tip_bottom.png);position: absolute;width: 11px;height: 6px;overflow: hidden;}
- .jfts_back{margin-bottom: -26px;padding: 18px;width: 260px;border: 1px solid #B1B1B1;background: #FEFEE9;}
- .jfts_word{bottom: 3px;left: 12px;position:relative;}
- .jfjd{position:absolute;left:78px;top:-1px;color:#000000;}
- .tip{border:0 none;border-radius:5px 5px 5px 5px;padding:8px;overflow:visible!important;}
- .tip_c{line-height:16px;overflow:visible!important;}
- #jindutiao{position:relative;margin:5px 0 5px 0;}
- .hide .jfts{display:none;}
- .show .jfts{display:block;}
- </style>
- <div id='jindutiao' class='hide' onmouseover='this.className="show"' onmouseout='this.className="hide"'>
- <p>
- <span class="pbg2"><span class="pbr2" style="width:{echo $jfper}px;"></span></span>
- </p>
- <div class='jfts'>
- <div class='jfts_back'></div>
- <div class='jfts_horn'></div>
- <div class='jfts_word'>{$post[authortitle]},积分 $wanfen1$wanfen2,距离下一级还需 {echo ($jfjdinfo[$jflevel][creditslower]-$jifen)} 积分</div>
- </div>
- </div>
- <dl class="pil cl" style="margin: 5px 10px 5px 20px;">
- <dt>积分</dt><dd><a class="xi2" href="memcp.php?action=credits" target="_blank">$wanfen1$wanfen2</a></dd>
- </dl>
- <!--{/if}-->
- <!--积分进度条end-->
复制 |
